How To split , separate surfaces with brep
Hi guys,
Simple task, but for some reason whatever I try doesn’t work. Basically want to crop all contours surfaces to 6 boundaries . So I only have surface which are inside these 6 curves ?
In green areas only.
Cheers
SectorsStepping.gh (851.1 KB)
Usually, boolean or split operations with multiple geometries will take a lot of time.
SectorsStepping_re.gh (845.6 KB)
SectorsStepping_re2.gh (843.0 KB)
another {maybe faster} option is to stick to curves for the trimming:
Thank you,
Yep, definitely takes long time on a laptop. Will try at work.
Maybe it will be faster with just surfaces and surf split, but can’t find a away to separate them?
Looks faster, but I will have to find an missing edge curve to create surface + surfaces which where not cut but still inside the boundary.
you’re right…for that you have to fix what’s self-intersecting, coming from the mesh contours themselves…
so here’s this, maybe only ‘faster’ by a bit or maybe almost just as slow :joy: - on this laptop the definition takes ~1.5 minutes to load
SectorsStepping_re2.gh (847.0 KB)
Thank you, what plugin are using for multiple split?
I don’t have it
no plug-in, it’s the grasshopper component split brep multiple
Found a better way. I used Mesh split first and then contour new meshes . Much much faster.
