mitch1
(Mitch)
April 25, 2022, 7:37pm
#1
I am able to save a bitmap as a jpg using the script from SampleViewCaptureToFile.py. I’d like to be able to set the jpg quality. I tried the following, but that doesn’t work and I can’t get very far figuring out why.
import System
import Rhino
import scriptcontext as sc
import sys
view = sc.doc.Views.ActiveView
if view:
view_capture = Rhino.Display.ViewCapture()
view_capture.Width = view.ActiveViewport.Size.Width
view_capture.Height = view.ActiveViewport.Size.Height
view_capture.ScaleScreenItems = False
view_capture.DrawAxes = False
view_capture.DrawGrid = False
view_capture.DrawGridAxes = False
view_capture.TransparentBackground = False
bitmap = view_capture.CaptureToBitmap(view)
if bitmap:
jpg_encoder = System.Drawing.Imaging.Encoder()
encoder_quality = System.Drawing.Imaging.Encoder.Quality()
encoder_params = System.Drawing.Imaging.EncoderParameters[0]
encoder_param = System.Drawing.Imaging.EncoderParameter(encoder_quality, 10)
encoder_params.Param[0] = encoder_param
bitmap.Save(filename, System.Drawing.Imaging.ImageFormat.Jpg, encoder_params)
dale
(Dale Fugier)
April 25, 2022, 8:22pm
#2
Hi @mitch1 ,
Here is a Python version of this:
import System
import Rhino
def _get_image_codec_info(image_format):
codecs = System.Drawing.Imaging.ImageCodecInfo.GetImageDecoders()
for codec in codecs:
if (codec.FormatID == image_format.Guid):
return codec
return None
def _save_jpeg_quality(bitmap, path):
# Get an image code
image_codec_info = _get_image_codec_info(System.Drawing.Imaging.ImageFormat.Jpeg)
# Create an Encoder object based on Quality
encoder = System.Drawing.Imaging.Encoder.Quality
# Create an EncoderParameters object.
# An EncoderParameters object has an array of EncoderParameter objects.
# In this case, there is only one EncoderParameter object in the array.
encoder_params = System.Drawing.Imaging.EncoderParameters(1)
encoder_param = System.Drawing.Imaging.EncoderParameter(encoder, 50)
filename = System.IO.Path.Combine(path, "test_quality_fifty.jpg");
bitmap.Save(filename, image_codec_info, encoder_params)
encoder_param = System.Drawing.Imaging.EncoderParameter(encoder, 100)
encoder_params.Param[0] = encoder_param;
filename = System.IO.Path.Combine(path, "test_quality_hundred.jpg");
# Save the bitmap as a JPG file with zero quality level compression
encoder_param = System.Drawing.Imaging.EncoderParameter(encoder, 0)
filename = System.IO.Path.Combine(path, "test_quality_zero.jpg");
def test_view_capture():
if not view:
return
if not bitmap:
return
path = System.Environment.GetFolderPath(System.Environment.SpecialFolder.Desktop)
if __name__ == "__main__":
test_view_capture()
Hope this helps.
– Dale
