I am able to instantiate components on the canvas with python code.
What I have not been able to figure out so far is how to (un)set component options like these:
I assume it must be possible somehow. Does anyone know?
It depends on the API for each component Class. But when creating Python components in bundled ‘dev-ops’ code, I just set the attribute on each one before adding it to the canvas or creating a user object etc.
Thanks for your reply @James_Parrott
Unfortunately I’m not sure what you mean by “bundled ‘dev-ops’ code“. – If you have a code example (setting attributes, creating user objects) you might want to share, that would be greatly appreciated.
gh_python_comp = GhPython.Component.ZuiPythonComponent()
gh_python_comp.Code = tool_code
gh_python_comp.IsAdvancedMode = True
gh_python_comp.Description = description
gh_python_comp.SubCategory = subcategory
gh_python_comp.Category = plug_in_name
gh_python_comp.Locked = locked
gh_python_comp.NickName = name
gh_python_comp.Name = name
GH_doc = ghdoc.Component.Attributes.Owner.OnPingDocument()
GH_doc.AddObject(docObject = gh_python_comp, update = False)
This shows positioning them:
GH_DOC = ghdoc.Component.Attributes.DocObject.OnPingDocument()
# search Grasshopper.Kernel.GH_ComponentServer().ExternalFiles(True, True)
# e.g. for the file_obj with a particular plug-in name in its path
user_obj = Grasshopper.Kernel.GH_UserObject(file_obj.FilePath)
comp_obj = user_obj.InstantiateObject()
comp_obj.Locked = False
sizeF = System.Drawing.SizeF(x, y)
comp_obj.Attributes.Pivot = System.Drawing.PointF.Add(
comp_obj.Attributes.Pivot,
sizeF
success = GH_DOC.AddObject(docObject = comp_obj, update = False)
if not success:
raise Exception('Could not add comp: %s to GH canvas' % comp_obj)
I figured out how to get the menu items:
import clr
clr.AddReference('Grasshopper')
import System
import Grasshopper as gh
import System.Windows.Forms as WinForms
doc = gh.Instances.ActiveCanvas.Document
compName = 'Graft Tree'
proxy = gh.Instances.ComponentServer.FindObjectByName(compName, True, True)
comp = proxy.CreateInstance()
comp.CreateAttributes()
comp.Attributes.Pivot = System.Drawing.PointF(100, 100)
doc.AddObject(comp, False)
# https://learn.microsoft.com/en-us/dotnet/api/system.windows.forms.toolstripmenuitem?view=windowsdesktop-10.0#properties
try:
menu = WinForms.ToolStripDropDown()
comp.AppendAdditionalMenuItems(menu)
for item in menu.Items:
item.Checked = False # <- has no effect
print(item.Text, item.Checked)
doc.NewSolution(True)
except:
print('failed')
But unchecking them seems to have no effect, unfortunately.
So I’m still looking for a way to access the underlying pieces of data directly in order to flip the flags on or off.
@DavidRutten How would one do that?
What does dir on the menu items show? Is there a setter or a toggle method that’s not associated with assignment in IronPython?
Aha! – calling .PerformClick() on the menu item seems to do the trick.
Still curious about better approaches that don’t involve simulating clicks in the UI.
