How to select surface in tekla
Inside Tekla Structures there is a possibility to select a surface on a object.
I think that this can be done in Grasshopper using API inside of C# component.
I know that i can import object to GH change it to the BREP explode it and then select a surface but i want that all input operations will be in tekla. This is a lot more user friendly, and lot faster than jumping beetwen Tekla-Rhino-Grasshopper.
Has anyone got solution for this? I am very bad in API and C# so inventing this will take me ages.
Hi @susi33 ,
Not quite sure that I understand your question but would you not just use the Tekla Surface Component to select a surface in Tekla? It’s a fairly new addition to the Tekla GH link so make sure that you have the latest version installed.
Yes!
You understand my request well, and this is exactly what i wanted. Thank you very much!
You’re welcome, glad I could help!
