I want remap object to top view. How can do that. I use ‘TransformObjects’ but it not working.
After remapping i’m use ‘Transform Objects’ to extrude objects.The result are polysurfaces, i want make curve like before it is extruded but not.
import scriptcontext
import Rhino
objects = rs.GetObjects("Select objects to project")
if objects:
cplane = rs.ViewCPlane()
form = rs.XformPlanarProjection(cplane)
obj=rs.TransformObjects( objects, xform, False )
#For make curve
Im try used ‘rs.DuplicateEdgeCurves’ but can’t join curve be created.
Thank you watching!
