starzred
(Starzred)
May 28, 2018, 7:40am
1
Dear All
Please excuse my simple question. I have a simple case here consisting of 2 branches {0} & {1}.
All I need to do is to change their orders so that {0} becomes {1}.
I have tried reverse list but that obviously wasn’t the correct choice.
Much appreciate if some kind hearts could lend a hand on this.
I have attached the script herewith. Many thanks in advance!
Kind regards
Yuatakatree branch renumber question.gh (4.7 KB)
Gijs
(Gijs de Zwart)
May 28, 2018, 8:35am
2
starzred
(Starzred)
May 28, 2018, 8:45am
3
Hi Gijs
Yes this is exactly what I need, you are a genius. Can I assume that if the tree has more indexes, I will hae to reorder them one by one this way or would there be a single command that simply reorders from front to back with one step?
Many thanks!
Gijs
(Gijs de Zwart)
May 28, 2018, 9:05am
4
I’m not saying there isn’t another way, but I don’t know to do it other than I posted.
Gijs
(Gijs de Zwart)
May 28, 2018, 9:20am
5
This works…
reorder branches.gh (3.2 KB)
Check this as well.
For this to work, you should uncheck “Maintain Path ” option ofTree Branch component to “Renumber ” via RMB popup menu .
tree branch renumber question_re.gh (9.3 KB)
starzred
(Starzred)
May 28, 2018, 2:22pm
7
Hi Gijs
Thank you for the options! much appreciated!
starzred
(Starzred)
May 28, 2018, 2:24pm
8
Hi HS Kim
Thank you very much, that does the job just as I needed, thank you for your help! much appreciated!
