For example, if I have GetObject() which is prompting the user to select an object.
But, instead of selecting an object the user inputs a number.
In this situation I want GetObject() to break and to get the number instead.
How can I do that?
How can I do that?
@Bogdan_Chipara, see if below helps:
import Rhino
def DoSomething():
go = Rhino.Input.Custom.GetObject()
go.GeometryFilter = Rhino.DocObjects.ObjectType.AnyObject
go.SetCommandPrompt("Select object, input number or press Enter")
go.AcceptNumber(True, True)
go.AcceptNothing(True)
get_rc = go.Get()
if get_rc == Rhino.Input.GetResult.Cancel:
print "Cancel"
elif get_rc == Rhino.Input.GetResult.Nothing:
print "Enter pressed"
elif get_rc == Rhino.Input.GetResult.Number:
print "Number:", go.Number()
elif get_rc == Rhino.Input.GetResult.Object:
print "Object Id:", go.Object(0).ObjectId
DoSomething()
c.
Hi @clement, thank you!
This is more complicated than I thought, so I need more help.
First, I don’t need just any object, I need a PointOnCurve
Second, I realized that I might need both the point and the number.
@Bogdan_Chipara, you’ll first have to prompt for a curve, then for a point and constrain to the picked curve. If you’ll pick a point on the curve, it will only return a point, so in order to also get a number, you’ll have to add a number option to the point picker. I am not sure if below is what you want, it allows to pick a point on the curve, or enter a number.
If no point is picked, it just prints the current option number
If a point is picked, it prints both, the point and the current option number
If a number is entered, it returns that, but you’ll get no point as no point was picked
import Rhino
def DoSomething():
# get a curve
gc = Rhino.Input.Custom.GetObject()
gc.GeometryFilter = Rhino.DocObjects.ObjectType.Curve
gc.SetCommandPrompt("Select curve")
if gc.Get() != Rhino.Input.GetResult.Object: return
# get point on curve
go = Rhino.Input.Custom.GetPoint()
go.SetCommandPrompt("Pick point on curve")
go.Constrain(gc.Object(0).Curve(), False)
# setup a number option
optNumber = Rhino.Input.Custom.OptionDouble(1.25, True, 0)
go.AddOptionDouble("MyNumber", optNumber)
get_rc = go.Get()
print "Cancel (ESC pressed)"
print "Nothing (Enter pressed)"
print "OptNumber:", optNumber.CurrentValue
print "Entered Number:", go.Number()
elif get_rc == Rhino.Input.GetResult.Point:
print "Point:", go.Point()
DoSomething()
c.
Great! Thank you @clement, very useful your examples!
