How to get GetNextDiscontinuity Points from Curve
Hi all,
I tried to to use GetNextDiscontinuity in Rhino Common to get the same result like the curve " Discontinuity " in grasshopper.
But i have no idea how to use it.
A small example would be great.
Thanks in advanced
I also have kissanime this same question. Anyone who can help is letgo appreciated.
I recently implemented it in GHPython like so, might help:
import Rhino as rc
def discontinuity(crv):
    """ Find G1_continuous discontinuities on a curve """
    # Get curve domain min/max
    tMin = crv.Domain.Min
    tMax = crv.Domain.Max
    # Perform search
    dctParams = []
    dctPoints = []
    getNext = True
    while getNext:
        getNext,t = crv.GetNextDiscontinuity(rc.Geometry.Continuity.G1_continuous,tMin,tMax)
        if not rc.RhinoMath.IsValidDouble(t):
            t = 0.00
        dctParams.append(t)
        dctPoints.append(crv.PointAt(t))
        if getNext:
            tMin = t
    return dctParams,dctPoints
Does admittedly seem a bit convoluted/complex having to implement a while loop, I might be missing a simpler approach here.
Thanks for your example
I am getting some unexpected errors when using the above with closed curves. It seems to be fixed with the below amendment.
continuity = Rhino.Geometry.Continuity.G1_continuous
tStart = crv.Domain.Min
tMin = tStart
# Perform search
dctParams = []
dctPoints = []
getNext = True
while getNext:
    getNext, t = crv.GetNextDiscontinuity(continuity, tMin, tMax)
    if not Rhino.RhinoMath.IsValidDouble(t):
        t = tStart
    dctParams.append(t)
    if getNext:
        tMin = t
