How to get DPI Scale during DynamicDraw?
I would like to get the factor, used to scale the text size (Draw2dText) and positions. For example text in the code below.
from Rhino import *
from Rhino.DocObjects import *
from Rhino.Geometry import *
from Rhino.Commands import *
from Rhino.Input.Custom import *
from System.Drawing import Color
def RunCommand():
  gp = GetDrawStringPoint()
  gp.SetCommandPrompt("Point")
  gp.Get()
  return gp.CommandResult()
class GetDrawStringPoint(GetPoint):
  def OnDynamicDraw(self, e):
    xform = e.Viewport.GetTransform(
      CoordinateSystem.World, CoordinateSystem.Screen)
    current_point = e.CurrentPoint
    current_point.Transform(xform)
    screen_point = Point2d(current_point.X, current_point.Y)
    msg = "screen {0}, {1}".format(screen_point.X, screen_point.Y)
    e.Display.Draw2dText(msg, Color.Blue, screen_point, False)
if __name__ == "__main__":
  RunCommand()
https://developer.rhino3d.com/api/RhinoCommon/html/P_Rhino_Display_DisplayPipeline_DpiScale.htm
Yes, that did the trick.
dpi = e.Display.DpiScale
DrawEventArgs.Display for anyone searching through the RhinoCommon API for more information.
Thank you @nathanletwory
You’re welcome.
How to get DPI scaling in non-Dynamic Draw
Is it the same way to get the DPI scale in Rhino 8? Assuming I’m working with python.
Yes.
import Rhino
import scriptcontext as sc
view = sc.doc.Views.ActiveView
if view:
    print(view.DisplayPipeline.DpiScale)
– Dale
