Hi There,
I am trying to use pyCharm as an IDE for editing rhinoscriptsyntax.
I’ve added the path below as a path variable.
%AppData%\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\IronPython (814d908a-e25c-493d-97e9-ee3861957f49)\settings\lib
This resulted in pyCharm to show autocomplete on the rhinoscriptsytax module, however, pyCharm keeps showing error “No module name rhioscriptSyntax”
Is there a way to solve this? Thanks in advance!
Tim
solution
Ok, I figured it out: you can add the path mentioned in my post above to pycharms project structure:
