How to find deletedObjects
        // TODO: start here modifying the behaviour of your command.
        Circle circle = new Circle(new Point3d(1,1,1),10);
        Circle circle1 = new Circle(Point3d.Origin, 100);
        Guid one = doc.Objects.Add(circle.ToNurbsCurve());
        Guid two = doc.Objects.Add(circle1.ToNurbsCurve());
        bool flag = doc.Objects.Delete(one, true);
        ObjectEnumeratorSettings objectEnumeratorSettings = new ObjectEnumeratorSettings();
        objectEnumeratorSettings.DeletedObjects = true;
        var data = doc.Objects.FindByFilter(objectEnumeratorSettings).ToList();
        return Result.Success;
When I run the above code,I find data.Count=0,not equal 1
Hi @chen3 ,
try these settings
                DeletedObjects = true,
                NormalObjects=false,
                LockedObjects=false
It is useful.Thank you
