Dear Rhino enthusiast I hope you can help me with an issue that I am having with the enclosed model.
I would like to fillet the outer polysurface to the inner rim that I designed by doing loft from one surface edge to the other.
Ideally I would like to have a 0.3mm uniform fillet along the external rim of the object, unfortunately it doesn’t work with FilletEdge.
I am open to any suggestion that would give me a smooth edge.
Thank you
Sun69mm.3dm (4.9 MB)
You’re trying to combine a mesh and polysurfaces, which can be tricky.
The fillet is possible but only with some extra effort. Here’s what I did:
- scaled the sun just 2D by 1.025 to have a bit more planar space around the hole.
- I modeled a BRep to subtract all the details of the hole. This BRep also has the fillets
- Turned the BRep into a mesh
- Subtracted the mesh from the sun
Sun69mm.3dm (2.1 MB)
Cheers Martin! I didn’t know it was possible to it this way. Very helpful!
The models need to be gold 3D printed, only last weekend I realised how expensive is the process and I need to reduce its volume to get decent quote.
It’s a great chance to try this method myself!
Thanks Francesca. If the above is a solution, please check the box
