Here the user interface:
if you press the CancelButton in the User-Interface the code enters line 611 (Dialog is shown)
here the SourceCode
nothing is working…the code will continue execution
THX for help Carsten
here the SourceCode
Hi Carsten,
you might try
raise Exception( 'message' )
HTH
Oh yes, this is a solution. For me it is working.
Do you also have a solution for a quiet exit without message?
THX Carsten
HI Carsten,
you might put your code into a function (def) and then use return statement to get out.
c.
