V5
Every article seems all about editing text size etc, I want to alter a dimension Length from e.g. 3.57 inch to 3.95 inch.
Now I could create a whole new dimension starting at the same place as the one I wish to alter, then delete the former, but is there a way of simply entering the new value and seeing the existing dimension grow its length ?
Useful when its tricky to locate the start point of the dimension, other objects attracting my snap in that area.
Curious why we can’t just edit the value of the dimension. It would be so easy: click a dimension, edit the length value and it updates. If I can create a dimension of specific length when I first draw the dimension why not be able to edit the dimension length directly.
Especially annoying since when you hover the scale axis of the gumball it says it is using “Scale1D”, but the Scale1D there behaves differently to normal Scale1D. There it takes a scale factor, while Scale1D the command takes 2 points and a distance.
