How to draw charts in grasshopper
Hi all,
It might be a simple question: How to draw different kinds of charts in grasshopper?
bar chart:
bar chart
line chart:
line chart
pie chart:
pie chart
test data:
Rhino chart test.csv (237 Bytes)
Many thanks!!
-HC
You could use native GH components but somewhat limited in use…There are some plugins that have the chart and graph features.
Thank you!! It does help!
Hi @HS_Kim,
I am playing around with the data visualization and having some questions about data structure: What is the difference between these two structures? And how to convert the upper one structure to the bottom one?
(From my understanding, the bottom one is the “Test{}” list and the upper one is just a list?)
Best,
-HC
If you don’t have prior knowledge of Datatree, I would recommend that you read the relevant resources before doing anything with GH…
https://modelab.gitbooks.io/grasshopper-primer/content/1-foundations/1-5/2_what-is-a-data-tree.html
And check this…
What can I say! Thank you so much.
I did figure out the data tree structure. It is similar to the Python data structure. Thanks Kim!
For reference, I would recommend using conduit to draw the graph for who is not familiar with grasshopper. Although Human UI did it very well.
