I want to create a method that given a list of strings creates nodes in a TreeView.
Apparently TreeNode could be an Array -> TreeNode[]
But I can’t figure out how to define an empty Array[TreeNode]() that I can add TreeNodes to. I tried everything I found on internet:
Array.__new__(TreeNode,0)
Array.CreateInstance(TreeNode,0)
List, ArrayList, simple [] just don’t work.
Could anyone shed some light how can I define an empty TreeNode array without fixing the size of it?
One solution I saw but didn’t try was deriving a class from System.Collections.IList creating my own list. I hope I don’t have to do that for such a stupid thing.
Thanks in advance.
Update:
This is my crazy-ass workaround. I don’t like it.
import clr
clr.AddReference("mscorlib")
clr.AddReference("System.Windows.Forms")
clr.AddReference("System.Drawing")
from System.Windows.Forms import Application, Form, StatusBar
from System.Windows.Forms import TreeView, TreeNode, DockStyle
from System.Drawing import Size
from System import Array
class IForm(Form):
def __init__(self):
self.Text = 'TreeView'
tv = TreeView()
root = TreeNode()
root.Text = 'Languages'
root_sub_list = ["CPython2","CPython3","IronPython","Jython","Cython","PyPy"]
root.Nodes.AddRange(self.add_list_node(root,root_sub_list))
tv.Parent = self
tv.Nodes.Add(root)
tv.Dock = DockStyle.Fill
tv.AfterSelect += self.AfterSelect
self.sb = StatusBar()
self.sb.Parent = self
self.Size = Size(220, 220)
self.CenterToScreen()
def AfterSelect(self, sender, event):
""" Name of the selected node will be displayed in the statusbar """
self.sb.Text = event.Node.Text
def add_list_node(self,subroot,node_list):
if isinstance(subroot,TreeNode) == False: return
node_array = Array.CreateInstance(TreeNode, 100)
for i in range(len(node_list)):
child_node = TreeNode()
child_node.Text = node_list[i]
node_array.SetValue(child_node,i)
node_array = node_array[:len(node_list)]
return node_array
if __name__=="__main__":
standalone = True # False if script is run inside Rhino
if standalone:
Application.Run(IForm())
else:
form = IForm()
form.Show()
first of all, you can’t create Arrays with variable lenghts. Arrays have a fixed length and lists have a variable length
What you can do though: you can add treenodes to treenodes, so no need for that fancy array creation. Maybe something like this:
tv = TreeView()
root = TreeNode("Languages")
for sub in root_sub_list:
tv.Nodes[0].Nodes.Add(TreeNode(sub))
Not tested, but something like this should work
Edit: Of course i would advise against doing Winforms in Python, use a proper IDE instead, to avoid such errors, but i know your take on this topic
This likey won’t work so maybe update with your json code then, but for your case it should be easier to iterate over normal python lists and use the Add Method of the treenodes created
# create variables
tv = TreeView()
# Add node to tv
tv.Nodes.Add(root)
# add sub nodes to first node in treeview
tv.Nodes gives you back a collection of all top-level nodes in your treeview. You can then index that collection and add child nodes to the nodes you get bakc by doing so.
