Dear ,
with rhino sdk C++ into CRhinoFileImportPlugIn
into rhino you have the windows Layers :
is it possible to create the same windows with Rhino SDK ? if yes , do you have some examples sources for adding the same windows ?
thanks
laurent
Dear ,
thanks
laurent
Hi @eraud,
The control used by the Layers panel is not exposed by the C++ SDK.
If you need to select one or more layers, you can use the RhinoSelectLayerDialog
and/or RhinoSelectMultipleLayersDialog
functions.
Does this help?
– Dale
Helo Dale ,
unfortunaly , I would like to create the same control as your layer control (with a tree struture) , how do to create it , is it an internal tool ?
thanks
Laurent
Helo Dale ,
thanks for your answer
thanks
Laurent
