How to close this object
Could you help me please to close this object with a G2 continuity Surface? Rhino Training Guide Level 2 exercise uses Position continuity with NetworkSrf to close it.
At first I tried with Rail Revolve but the axis isn’t symmetric, so I tried the others face building commands but I’m not able to close it with any of them.
Thank you
Handset 003.3dm (301.8 KB)
Hi @Bartleboom
Unless having the cap as a single surface is important, I’d go for an approach using a (trimmed) surface for the flatter part of the cap and then using BlendSrf to create the transition between the two.
HTH, Jakob
A very useful method!
Thank you very much @Normand
Regards
