How to cast RhinoObject to Curve
Hi, I’m writing c# plugin for Rhino 5. I need to select one or more surfaces , draw one line and find intersection points between them if there are any. To satisfy object types in “CurveSurface()” the line must be “Curve”. I can’t cast created line as curve object. Could you help me please!
Rhino.DocObjects.ObjRef[] surfs;
            Rhino.Input.RhinoGet.GetMultipleObjects("Select Polysurfaces & surfaces", true,
                Rhino.DocObjects.ObjectType.Surface | Rhino.DocObjects.ObjectType.PolysrfFilter, out surfs);
            Point3d Start = new Point3d(0, 0, 100);
            Point3d End = new Point3d(0, 0, -100);
            Guid line = doc.Objects.AddLine(Start, End);
            Rhino.DocObjects.RhinoObject ObjLine = doc.Objects.Find(line);
// CAST  line to Curve - error
            **Curve cLine =ObjLine.Curve();**
            Rhino.Geometry.Surface surf = surfs[0].Surface();
            double tl = 2.1 * doc.ModelAbsoluteTolerance;
            Rhino.Geometry.Intersect.CurveIntersections Cross = Rhino.Geometry.Intersect.Intersection.CurveSurface(cLine, surf, 0.001, tl);
You could make a LineCurve object directly, without adding it to the document.
LineCurve lc = new LineCurve(new Point3d(0,0,100), new Point3d(0,0,-100));
Or, create a curve from the Line:
Line l = new Line(new Point3d(0,0,100), new Point3d(0,0,-100));
Curve crv = l.ToNurbsCurve();
Thank you!
But how could be converted existing objects to specific types(surfaces, curvs …). after using Find command?
To me, your code looks good (it should work), but you don’t check for errors.
Like so, you could find the error:
if (line == Guid.Empty)
   RhinoApp.WriteLine("The line could not be added.");
if (ObjLine == null)
  RhinoApp.WriteLine("The object could not be found");
Curve cLine = ObjLine.Curve();
Yes, I skip the error checks for better readability.
The line
could not be compiled but I think that the solution is:
Curve cLine =ObjLine.Geometry as Curve;
May be this is the way for converting from RhinoObject to specific type.
Thank you for the support
I hope only on the forum and not in your code :wink:
I think the best way in this case is:
ObjRef oRef = new ObjRef(line)
Curve cLine = oRef.Curve();
Thank you! :slight_smile:
This is exactly what I’m looking for!
