Hi everyone,
I am working on a series of custom c# components making use of custom classes and objects wrapped in Goo transferred between components.
In my component, I would create a Goo object to save the input data and a new object extracting the duplicate of the value. For example something like this:
CustomClass item = new CustomClass();
CustomClassGoo itemgoo = new CustomClassGoo();
DA.GetData(0, ref itemgoo);
item = itemgoo.Value.Duplicate();
This is how the Duplicate() method would be implemented:
public CustomClass Duplicate()
item.ID = ID;
item.name = name;
return item;
I essentially create a new object, copy all the properties and return this new object.
I have now realised that after using item = itemgoo.Value.Duplicate(), when I call methods on it, this methods change the object that is passed as input. To explain myself better, in component 1 I create an object and I feed it in component 2; in component 2 I create a duplicate of the object and then call some methods; these methods have effect on the object created in component 1.
How can I avoid this?
Many thanks
