How to Assign Items to Branches
Hello
Is there a native way component to assing items to branches using integers as a mask? Elefront’s “Create Tree” component somehow works but doesn’t respect initial hierarchy of branches.
This is what I came up with using C#. I am just curious if there’s a better easier way.
    DataTree<Curve> assignedItems = new DataTree<Curve>();
    for (int i = 0; i < I.BranchCount; i++) {
      GH_Path actualPath = new GH_Path(i);
      for (int j = 0; j < I.Branch(actualPath).Count; j++) {
        int p = M.Branch(i)[j];
        GH_Path newPath = new GH_Path(i, p);
        assignedItems.Add(I.Branch(i)[j], newPath);
    R = assignedItems;
Thanks
An example to play with:
AssignItemsToDatatreeByMask.gh (8.4 KB)
Before I discovered the Elefront Create Tree component I usually used the Replace Paths component.
An example to play with would be nice
I’ve added sample file to the post
Create Tree does the job as long as you provide him the complete path, not only the second level of the branch.
AssignItemsToDatatreeByMask.gh (17.4 KB)
using @TomTom Fast Replace Path… if you could create the new paths inside the code would be interesting, but it seems to have a good performance.
AssignItemsToDatatreeByMask.gh (25.3 KB)
hick.gh (15.7 KB)
Would love to see a native component similar to Elefront’s Create Tree component.
I’ve gotten Replace Path to work but it requires additional components to do what Create Tree does in a single component.
I’m hoping that this is worthy of a feature request.
