How to access TextDot CRC
I’m looking for help using the DataCRC() method.
I’m trying to return the DataCRC for a Textdot, but the code doesn’t seem to be working as expected. The following code snippet sets rObj to a Rhino.Geometry.TextDot, but then when I try to use the DataCRC method it only returns 0 instead of a normal CRC value.
Do I need to be accessing the Textdot differently?
rObj = rs.coercegeometry(GUID)
crcval = rObj.DataCRC(0)
Is should add this code snippet works on other geometry types (curves, breps) so I’m confused why it isn’t working in this case
Thanks
Hi @NavArch,
Thanks for reporting.
– Dale
@Dale,
Is there a similar issue with blocks (InstanceReferenceGeometry)?
rs.coercegeometry(blockGUID) does return a Rhino.Geometry.InstanceReferenceGeometry object, but again then calling DataCRC(0) returns a value of 0.
Thanks
Hi @NavArch,
Same story as above - I’ll do the latter when I’m doing the former.
– Dale
@dale
I see progress was made based upon the YouTrack comments. When do you expect these updates to be pushed out?
Hi @NavArch,
Looking at the issue, the release target is set to 8.28.
Let me know if you want to test an internal build.
Thanks,
– Dale
OK I’m 8.27 right now. Its not a huge issue to wait for 8.28. If it should come out in the next month that will be fine
RH-91145 is fixed in Rhino 8 Service Release 28
Thanks for the notification. I can confirm that ObjCRC now works for dots and blocks as expected
