How explode a curve into segment and find the length of them
Hi !
I’m trying to create a new component for grasshopper. To do it, I use Visual Studio community 2017 and C#.
I’m looking for a solution to explode a curve into multiple segment and then find the length of these segments.
Someone know how to do it ? I can’t find the right syntax…
Thanks a lot.
Mathis
Explode how? You want individual spans, or split the curve at discontinuities? Or explode a polycurve into subcurves?
ps. You can measure the length of the sub-domain of a curve, there’s no need to explode the curve into new curves just to measure lengths.
My final goal is to measure the lengths of segments of a polygon. If you think there is no need to explode the polygon it’s perfect!
What syntax should be applied to achieve this ?
Is it for learning?
Why not use the built in explode component + curve length?
Or am I misunderstanding the question?
Polygons are fairly easy because they are polylines, and polylines are made up of line segments, and those have a Length property. It’s also easy to figure out how many segments a polyline consists of: polygoncomponent.cs (2.1 KB)
It’s to add a new component to a plugin. So I can’t use grasshopper component. I have to use C# and visual studio.
Sorry my english is not really good…
Thank you very much David !
@DavidRutten @Le_Pallier I wish to get the line length using GHPython. I am unable to proceed right now.
polyline1 = rg.Rectangle3d.ToPolyline(rect1)
polylineseg1 = rg.Polyline.GetSegments(polyline1)
polylineseg2 = polylineseg1[1]
I want the length of the line segments.
Thanks in advance.
vijesh
Try to translate this to P.
Curve_GetSegments_V1.gh (9.5 KB)
Here’s one approach:
230131_GetPolylineSegmentsLength_00.gh (6.6 KB)
Curve[] segments = inputCurve.DuplicateSegments();
// calculate the length of each segment and add it to a list
List<double> segmentLengths = new List<double>();
foreach (Curve segment in segments)
    segmentLengths.Add(segment.GetLength());
