Tested both [after restart] also on a new file with just a box.
same …
But ! I’m testing with the [thing you don’t like…] 3Dconnexion device. and so the issue is in there only.
the Linked viewports is working if I pan the view with the trackpad .
It used to work fine with the 3DX device in R7… [unless my memory is incorrect, as I don’t have R7 to check]
Regardless here’s System info
Summary
Rhino 8 SR0 2023-9-28 (Rhino 8 BETA, 8.0.23271.13234, Git hash:master @ 4acd4a788d5f9e7999c3d49c07cdd2f60038b920)
License type: Commercial, build 2023-09-28
License details: Cloud Zoo
Expires on: 2023-11-12
Apple macOS Version 13.5.2 (Build 22G91) (Physical RAM: 96Gb)
Mac Model Identifier: Mac14,6
Language: en-TH (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M2 Max
Color LCD (1728 x 1117 @ 120.00Hz)
Sidecar Display (1366 x 1024 @ 60.00Hz)
USB devices
Generic: USB3.0 Card Reader
VLI Inc.: USB 2.0 BILLBOARD
Wacom Co.,Ltd.: Wacom Intuos Pro M
3Dconnexion: SpaceMouse Enterprise
VIA Labs, Inc. : USB Billboard Device
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
/usr/lib/usd/libIex.dylib
/usr/lib/usd/libHalf.dylib
/usr/lib/usd/libAlembic.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/usd/libosdCPU.dylib
/usr/lib/usd/libImath.dylib
/usr/lib/usd/libIlmThread.dylib
/usr/lib/usd/libIexMath.dylib
/usr/lib/usd/libtbb.dylib
/usr/lib/usd/libMaterialXCore.dylib
/usr/lib/usd/libMaterialXFormat.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/usr/lib/swift/libswiftExtensionFoundation.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftExtensionKit.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/Users/akashlotan/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/bella_rhino.rhp/libbella_dotnet_native.dylib
/Users/akashlotan/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/DatasmithRhino7.rhp/DatasmithFacadeCSharp.dylib
/Users/akashlotan/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/DatasmithRhino7.rhp/libtbbmalloc.dylib
/Users/akashlotan/Library/Application Support/McNeel/Rhinoceros/packages/8.0/IntelDenoiser/0.6.7/libtbb.12.dylib
/Users/akashlotan/Library/Application Support/McNeel/Rhinoceros/packages/8.0/IntelDenoiser/0.6.7/libOpenImageDenoise.1.4.3.dylib
/Users/akashlotan/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/bella_rhino.rhp “Bella” 23.4.0.0
/Users/akashlotan/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/DatasmithRhino7.rhp “Datasmith Exporter” 5.3.0.0
/Users/akashlotan/Library/Application Support/McNeel/Rhinoceros/packages/8.0/IntelDenoiser/0.6.7/IntelDenoiser.Mac.rhp “IntelDenoiser.Mac” 1.0.0.0
/Applications/RhinoBETA.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.0.23271.1002
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.0.23271.13234
/Applications/RhinoBETA.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.0.23271.1002
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.23271.13234
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.0.23271.13234
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.0.23271.13234
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.0.23271.13234
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.0.23271.13234
/Applications/RhinoBETA.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.0.23271.1002
/Applications/RhinoBETA.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.0.23271.1002
/Applications/RhinoBETA.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.0.23271.1002
/Applications/RhinoBETA.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.0.23271.1002
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.0.23271.13234
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.0.23271.13234
BTY it would be great to devise a system that will auto link System Info to user’s … [with user consent] You probably asks for it 100 times a day …
thanks a lot
