How do I resize a dockbar in Rhino 8
I am building a Rhino plugin in CSharp/Dot net.
This plugin creates dockbars similarly to SampleCsDockBar project.
I need my dockbar to be docked to the right, with a specific width.
How can I achieve that?
I am not happy with the solutions to Resize docked panel from code and Automatic Resize Behavior for DockBar in WPF Plugin
I was able to get it docked to the right easily:
      DockBarCreateOptions create_optionsR = new DockBarCreateOptions
        DockLocation = DockBarDockLocation.Right,
        Visible = true,
        DockStyle = DockBarDockStyle.Any,
        FloatPoint = new System.Drawing.Point(100, 100)
      MyDockBar.Create(create_optionsR);
But I cannot set the width. Things I’ve tried after the creating of the DockBar:
MyDockBar.Dock(DockBarDockLocation.Right, new System.Drawing.Rectangle(0, 0, 400, 600));
((WpfHost)MyDockBar.WinFormsContent).ClientSize = new System.Drawing.Size(400, 600);
((WpfHost)MyDockBar.WinFormsContent).Bounds = new System.Drawing.Rectangle(0, 0, 400, 600);
((WpfHost)MyDockBar.WinFormsContent).Width = 500;
Things I’ve tried before the creation of the DockBar:
    public MyDockBar() : base(MyPlugIn.Instance, BarId, "Stage selection")
      WpfHost host = new WpfHost(new MyPluginView(), null);
      host.MinimumSize = new System.Drawing.Size(400, 100);
      SetContentControl(host);
Is there a way to change the width?
I am also open to simulating mouse click-drag-release if that’s the only solution.
This plugin is intended to be used in-house by several users. I am also open to updating user settings/configuration if I can save the dockbar position and size.
SystemInfo:
Rhino 8 SR19 2025-5-12 (Rhino 8, 8.19.25132.01001, Git hash:master @ 57e3eb280b0f32cbe59f53a554be5e8ffa66fc36)
License type: Commercial, build 2025-05-12
License details: Stand-Alone
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 12GB)
.NET 7.0.20
Computer platform: LAPTOP  - Plugged in [48% battery remaining]
  Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 5-19-2020 (M-D-Y).
        - Windows Main Display is laptop's integrated screen or built-in port
  Primary OpenGL: NVIDIA GeForce GTX 1650 (NVidia) Memory: 4GB, Driver date: 7-5-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 451.67
    > Integrated accelerated graphics device with 1 adapter port(s)
OpenGL Settings
  Safe mode: Off
  GPU Tessellation is: On
  Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
  Anti-alias mode: 4x
  Mip Map Filtering: Linear
  Render version: 4.6
  Shading Language: 4.60 NVIDIA
  Driver Date: 7-5-2020
  Driver Version: 27.21.14.5167
  Z-Buffer depth: 24 bits
  Total Video Memory: 4 GB
  C:\guillaume\bracedesigner\build\Debug\net7.0-windows\OsskinRhinoPlugin.rhp	"OsskinRhinoPlugin"	1.0.0.0
  C:\Program Files\Rhino 8\Plug-ins\Commands.rhp	"Commands"	8.19.25132.1001
  C:\Program Files\Rhino 8\Plug-ins\rdk.rhp	"Renderer Development Kit"
  C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp	"Rhino Render"	8.19.25132.1001
  C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp	"RDK_EtoUI"	8.19.25132.1001
  C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp	"Snapshots"
  C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp	"MeshCommands"	8.19.25132.1001
  C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp	"RhinoCycles"	8.19.25132.1001
  C:\Program Files\Rhino 8\Plug-ins\import_STL.rhp	"STL Import"
  C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp	"Toolbars"	8.19.25132.1001
  C:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp	"3Dconnexion 3D Mouse"
  C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp	"Displacement"
  C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp	"SectionTools"
You could try using WindowLayouts as this is just internal.
Thanks Callum Sykes and sorry for the late reply. Actually, the plugin seems to remember its panel configuration when the user exits Rhino cleanly (which I was not doing in debug), so this is not really an issue anymore (the user just adjusts the first time they use our plugin).
