When I try to treat the tree as a list and find out its length I get an error that it does not have an attribute length.
I think you might need to use the tree helper functions. This might help?
DataTrees have BranchCount and DataCount properties. There’s no Length property.
Yes, I try to use this but I could not fine a way to iterate over the number of branches.
David can you give me an example (could be csharp) iterate, say I have a tree {0,n} I want with code to extract the data from each branch.
e.g.: I have this tree
I successfully get this:
But how can I split back this tree into 4(or as many as they are) lists?
nvm,
I got it, thanks for your time @chanley, @DavidRutten.
it was simpler than I thought. just 5-6 lines of code
