Hi all,
I am trying to figure out the process for creating my own folders within Render LIbraries.
I thought I’d be able to right-click or use a dropdown to create a folder.
Also, I thought I’d find the materials I’ve created in a file in there somewhere, too.
So: How do I create a my own folder that shows up in Render Libraries? I may be missing something obvious, but read over the manual & tried making my own folder (“Tiles”) but cannot see it.
I think you’re on Windows from the screenshots and this should work. I see you have a folder called Tiles that you added as a custom folder. Does that folder still exist in the same location it did when you set that folder as a custom folder for the Render libraries? I think you might have added a folder and then renamed it to Tiles but the folder location was never set. Use the … icon and then browse to and find the folder on your computer. Was that it? Note the name will have a path relative to the drives on your computer.
