I’ve tried many methods but can’t seem to make the background transparent. Can you help me with this using C#?
using Rhino.PlugIns;
using Eto.Forms;
using Eto.Drawing;
using System;
using System.Runtime.InteropServices;
using System.Drawing; // System.Drawing.Common for per-pixel bitmap rendering
namespace RadialMenuPlugin.Controls
public class TransparentForm : Form
protected PlugIn _MainPlugin;
public TransparentForm(PlugIn plugin) : base()
Title = "Radial Menu";
WindowStyle = WindowStyle.None;
AutoSize = false;
Resizable = false;
ShowActivated = false; // Important for WPF transparency
Padding = new Padding(0);
MovableByWindowBackground = false;
// Eto chỉ định là trong suốt
BackgroundColor = Colors.Transparent;
// User's exact WPF transparency approach
Styles.Add<Panel>("transparent", control =>
try
var wpfWindow = (System.Windows.Window)control.ControlObject;
ApplyTransparency(control, wpfWindow);
catch (Exception ex)
System.Diagnostics.Debug.WriteLine($"Direct WPF cast failed: {ex.Message}");
// Fallback to reflection approach
TryApplyWpfTransparencyReflection(control);
// Create transparent panel and apply the style
var transparentPanel = new Panel();
transparentPanel.Style = "transparent";
Content = transparentPanel;
_MainPlugin = plugin;
// Windows-specific setup sau khi load
Load += OnFormLoad;
// ESC để đóng
KeyUp += (s, e) =>
if (e.Key == Keys.Escape)
_OnEscapePressed(s, e);
public void KeyPress(KeyEventArgs e)
OnKeyDown(e);
/// <summary>
/// User's exact ApplyTransparency method for perfect WPF transparency
/// </summary>
/// <param name="control">The Panel control</param>
/// <param name="window">The WPF window</param>
private void ApplyTransparency(Panel control, System.Windows.Window window)
try
control.BackgroundColor = Eto.Drawing.Colors.Transparent;
window.AllowsTransparency = true;
window.Background = System.Windows.Media.Brushes.Transparent;
window.Topmost = true;
window.ShowActivated = false;
System.Diagnostics.Debug.WriteLine("✅ User's exact WPF transparency method applied!");
System.Diagnostics.Debug.WriteLine(" - control.BackgroundColor = Transparent");
System.Diagnostics.Debug.WriteLine(" - window.AllowsTransparency = true");
System.Diagnostics.Debug.WriteLine(" - window.Background = Brushes.Transparent");
System.Diagnostics.Debug.WriteLine(" - window.Topmost = true");
System.Diagnostics.Debug.WriteLine(" - window.ShowActivated = false");
System.Diagnostics.Debug.WriteLine($"ApplyTransparency failed: {ex.Message}");
/// <summary>
/// Reflection-based fallback for WPF transparency when direct cast fails
/// </summary>
/// <param name="control">The Panel control to apply transparency to</param>
private void TryApplyWpfTransparencyReflection(Panel control)
try
var controlObject = control.ControlObject;
// Check if the underlying control is a WPF Window
if (controlObject != null && controlObject.GetType().FullName.Contains("System.Windows.Window"))
// Cast to System.Windows.Window using reflection
dynamic wpfWindow = controlObject;
// Apply the same transparency settings
wpfWindow.AllowsTransparency = true;
// Set WPF transparent background
var brushesType = Type.GetType("System.Windows.Media.Brushes, PresentationCore");
if (brushesType != null)
var transparentBrush = brushesType.GetProperty("Transparent")?.GetValue(null);
if (transparentBrush != null)
wpfWindow.Background = transparentBrush;
wpfWindow.Topmost = true;
wpfWindow.ShowActivated = false;
System.Diagnostics.Debug.WriteLine("✅ Reflection-based WPF transparency applied successfully");
System.Diagnostics.Debug.WriteLine($"Reflection WPF transparency failed: {ex.Message}");
private void OnFormLoad(object sender, EventArgs e)
System.Diagnostics.Debug.WriteLine("Form loaded - WPF transparency should be active");
System.Diagnostics.Debug.WriteLine("If background is still visible, the underlying platform may not be WPF");
protected void _OnMouseMove(object sender, MouseEventArgs e)
if (!HasFocus)
Focus();
protected virtual void _OnCloseClickEvent(object sender)
Visible = false;
protected virtual void _OnEscapePressed(object sender, KeyEventArgs e) { }
