I have a dictionary. {key: value, key2: value2}, Dict = {(4, 5): (2.733), (5, 2): (2.4533), (6, 2): (4.533), (7, 3): (1.333)}.
How could I reorder the key part to NewDict = {(0, 1): (2.733), (0, 2): (2.4533), (1, 0): (4.533), (1, 1): (1.333)}
This is what I do. But it does’t reordered the number as I want.
Imax = Max(Dict.keys()[0])
jmax = Max(max.keys()[1])
values= Dict.value()
for m in range(Imax ):
thanks for the reply.
What I want is not sort the dictionary. But only rewrite the key, not the values. so the values keep the same,but replace the keys by their index in the dictionary.
Then you should get a sorted list of keys based on running the sorted function on the d.keys(). Use that list to remap your dictionary. I don’t have access to my computer at the moment, so I can’t put a good sample together but hopefully what I’m explaining makes sense.
Here is the example for what I want. How do I sort the key = (i,j)
Pt = {}
for i in range(5):
for j in range(5):
x = i
y = j
z=0
Pt[(i,j)] = (x,y,z)
#for this dictionary If I Take 3 index out like NewDict {(4, 3): (4, 3, 0), (0, 0): (0, 0, 0), (1, 3): (1, 3, 0)}
rewrite the key (k,m) in the same sequence to the older (i,j).
The result I want is {(0,0):(0, 0, 0),(0, 1): (1, 3, 0), (1, 1): (4, 3, 0) }
