you might also subscribe to an idle event which does not fire when Rhino is busy. Below is a simplified example script which shows the current time in the statusbar, run it again to turn it OFF.
import Rhino
import scriptcontext
from datetime import datetime
def MyIdleEvent(sender, e):
message = datetime.now().strftime('%Y-%m-%d %H:%M:%S')
Rhino.UI.StatusBar.SetMessagePane(message)
def DoSomething():
key_idle = "MyIdleEvent"
if scriptcontext.sticky.has_key(key_idle):
print "Time display OFF"
Rhino.RhinoApp.Idle -= scriptcontext.sticky[key_idle]
scriptcontext.sticky.Remove(key_idle)
else:
print "Time display ON"
scriptcontext.sticky[key_idle] = eval(key_idle)
Rhino.RhinoApp.Idle += eval(key_idle)
if __name__=="__main__":
DoSomething()
I have not tried how it behaves if more complex scripts are fired from the event. In general try to leave the event as fast as possible, the event fires often !
c.
