Is there a way to run Rhino with a script in the background? Right now I call
“C:/Program Files/Rhinoceros 5 (64-bit)/System/Rhino.exe” /nosplash /runscript=“! _-RunPythonScript script.py”
…but this opens Rhino in the standard interactive mode while executing the script. It’d be better if it was possible to have it run in the background so it doesn’t pop up in the user’s face while the script is executing.
Hi Marcus,
The only way to run Rhino in the background it to run it via ActiveX automation (e.g. COM). Here is some background:
http://wiki.mcneel.com/developer/automation
And here is a VBScript sample:
https://github.com/mcneel/rhinoscript/blob/master/TestAutomateRhino.vbs
To run VBScripts, use CScript.exe.
Note, the .NET languages are also capable of automating Rhino.
– Dale
