I created a dome with masonry technique. The entire dome is made of bricks. But bricks are not planar. Many plugins I’ve seen work with mesh surfaces. I can’t create the dome from mesh surfaces. Because the mesh system does not work when you divide the dome into equal parts. Is there a way to analyze brick elements in Grasshopper? I am attaching the code related to modeling of the dome.
Thank you.
dome.gh (21.1 KB)
