Hey team, I am trying to create a basket for a ring, and get stuck with this same problem. I sweep the rails to create the shape, then I run into overlapping surfaces. I’ve tried using a few commands to cut away and merge, but it never works. I am looking to merge them together so the flow into each other nicely. Any thoughts or help?
I took Two of your half-loop curves (an “end” and a “side” curve), and simply used _FitCrv to make considerably more simple versions of the curves you have. I then used a blend between two of the curves, and everything else was either a mirror or a rotation of the two curves, to create a single smooth closed curve.
I then used your original cradle box profile, rotated it so that it was vertical to the sweep plane, and Sweep1, while adjusting the vertical position to prevent a crease or intersecting geometry.
The top was simply chopped off using a crude boolean, and then edge softening was applied. This is very rough, but I wasn’t very sure on your flexibility of the profile.
Sorry if it isn’t helpful, but you are welcome to the file. All of my work is on the blue layer, so hopefully it should be reasonably obvious.
Thanks for the feedback. I see what you’ve done, but Its gets away from the degisn too much. We need the ends of the basket arms to intersect like a ‘W’. not wave like an ‘S’. I would like like to merge the two arms together.
This below is also likely not quite to your intent, but this version is based on a single-surface offset, with parts cut out using cylinder trims. But the idea is reasonably smooth. I think it is closer to the original W shape you had in mind, but the scale and surfacing is not likely the form you wanted.
Perhaps someone else has a better execution route here!
my first and simple Idea would be to use symmetric and identical Y’s.
the Merging-Part will be a plane / see the red curve
with this approach, only the green parts are different (and not very nice in my fast, sketch-like-approach, so the file is not worth sharing).
Flow / FlowAlongSrf
build everything on a linear (extrusion) or even planar surface.
or even just a straight curve.
then use _flow or _flowAlongSrf to get everything on the ellipse-Shape.
I expect that its getting hard to have a nice, continuous / not changing profile.
(not sure if this approach is satisfying)
SubD
for sure will give you best ratio between time and result.
other Surface-Layout
if you want most control over the Y-Area (and a lot more work then subD) you have to use a different layout of the surfaces. Each of the U-like parts (your sweep surfaces) will become several surfaces:
maybe 1x Front, 1x Back, 2x Sides, 4xEdges/Fillets/Blends. … or even more complex - at least in the area of the Y.
looking forward to see your final approach - kind regards - “tom_p”
