How can I connect multiple points to one single points with a polyline
it’s been a while since the last time I did use grasshopper but basically I have multiple points that need to be connected to one single point, with a straight line, which then I can use to get the distance/length
I though doing something with lists, but so long so forth nothing is working on
Hi
It seems you can connect by Line component, it will seek two input, first one could be your destination point and second one could be all other point that you can hold shift while linking or merge those point before link to Line component
