How can I add such a shortcut to change colors?
I know Display Color And Othre , But I want a shortcut like in the video .
It’s a popular script that’s used by many. Here is the file that you could use when you assign it to a custom icon. Also, put this “Set wireframe color” as a name for the icon. And this is the icon itself (same as the “Object properties” icon):
! -_Runscript (
Option Explicit
' Script written by Guilherme C. Webster, Jan/2005
' Designed to quicly change the wireframe color of any objects in Rhinoceros 3D
Sub WireColor
Dim arrObj, lngColor
arrObj = Rhino.GetObjects ("Select objects to change wireframe color", 0, True, True)
If Not IsNull (arrObj) Then
lngColor = Rhino.GetColor
Else
Exit Sub
End If
If Not IsNull (lngColor) Then
Rhino.ObjectColor arrObj, lngColor
Else
Exit Sub
End If
End Sub
WireColor
And here is another script to quickly change the render colour. However, it has one disadvantage: If you assign a custom render colour and immediately press “Undo”, the object(s) will be made pitch black. Other than that, it works fine. Name of the command is “Set render color”.
This is the icon:
! -_Runscript (
Option Explicit
' Designed to quicly change the render/material color of any objects in Rhinoceros 3D
Sub RenderColor
Dim arrObj, strObj
Dim intIndex
Dim lngColor
arrObj = Rhino.GetObjects ("Select objects to change material color", 0 , True, True, True)
If Not IsNull(arrObj) Then
Else
Exit Sub
End If
Rhino.command ("-_properties m o r c 0,0,0 enter enter")
Rhino.ObjectMaterialSource arrObj, 1
For Each strObj In arrObj
intIndex = Rhino.ObjectMaterialIndex(strObj)
Rhino.MaterialColor intIndex, lngColor
Next
Rhino.print "Material color changed sucessfully."
Else
Exit Sub
End If
End Sub
RenderColor
Thank you so much
Hello - for quick one-shot color setting to known colors:
! _-Properties _Pause _Object _Color _Object 255,0,0 EnterEnd
