Hello Everyone, I was curious if someone already solved this problem. I would like to send object models within context bake from hops. Currently, I don’t get any result when I do that. (Also as a geometry input does not seam to work)
My guess is because of the headless compute environment?
In my experience, Hops doesn’t currently support new R8 model object components, parameters or similar. If you’re just wanting to grab the output, what you my be able to do is to grab each of the geo/name/layer etc outputs separately using the “best-fit” outputs (brep / mesh / string) and recombine them once the Hops outputs have been passed back into the main canvas.
Andy Payne mentions here that model objects support within Hops is on the radar, but there is no further update as of this post.
No worries Felix. If you haven’t seen it, Andy has mentioned that an update to Hops for the next Rhino 9 WIP should be bringing in model.objects support.
