Hops bug? Could not load file or assembly 'System.Collections.Immutable
Hi :waving_hand:
Hops component returns:
Error building script: Could not load file or assembly ‘System.Collections.Immutable, Version=9.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a’. Could not find or load a specific file. (0x80131621): component “C# Script” (a8987d9a-2383-45bf-ab13-6743248eb333)
If I open the gh file executed in Hops then everything looks fine, no complains from C# component.
The files were created initially in Rhino 8.
Files attached below.
Rhino 9 SR0 2026-6-16 (Rhino WIP, 9.0.26167.11545, Git hash:master @ 57b70c19c1a95d556312e40efd60cd1c4e9f7aaf)
License type: Commercial, build 2026-06-16
License details: Cloud Zoo
Expires on: 2026-07-31
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 32GB)
.NET 10.0.9
Computer platform: DESKTOP
Standard graphics configuration using DirectX
Primary display: AMD Radeon Pro W5700 (AMD) Memory: 8GB, Driver date: 9-25-2025 (M-D-Y). DirectX(11)
Accelerated graphics device with 7 adapter port(s)
  • Secondary monitor attached to adapter port 0
  • Windows Main Display attached to adapter port 1
Secondary graphics devices.
None found.
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Zen MAX_THREADS=64.
C:\DEV\Projects\RhinoMCP\rhino\plugin\bin\Debug\net8.0\RhinoMcpPlatform.rhp “RhinoMcpPlatform” 0.2.0.0
  • 3 custom plugins
    C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.26167.11545
    C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
    C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26167.11545
    C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.26167.11545
    C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26167.11545
    C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
    C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26167.11545
    C:\Program Files\Rhino 9 WIP\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 9.0.26167.11545
    C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26167.11545
    C:\Program Files\Rhino 9 WIP\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 9.0.26167.11545
    C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
    C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
Margins axis.gh (11.0 KB)
Parent definition.gh (5.3 KB)
@AndyPayne , could you take a look?
Probably the hint in NET 8 version used in hops?
\AppData\Roaming\McNeel\Rhinoceros\packages\9.0\Hops\0.17.0\rhino.compute\rhino.compute.runtimeconfig.json:
“runtimeOptions”: {
"tfm": "net8.0",
"includedFrameworks": \[
    "name": "Microsoft.NETCore.App",
    "version": "8.0.0"
    "name": "Microsoft.AspNetCore.App",
    "version": "8.0.0"
"configProperties": {
  "System.GC.Server": true,
  "System.Reflection.Metadata.MetadataUpdater.IsSupported": false,
  "System.Runtime.Serialization.EnableUnsafeBinaryFormatterSerialization": false
