I try to filter away some Null points from a list with GhPython but trying the following code I still end up having 24 Null points in my lists…
import Rhino
if pt_list:
P = []
for pt in pt_list:
# Tried both variants below, but no go
if pt: <- Does not filter away
if pt is not None: <- Does not filter away
P.append(pt)
My fantasy fails on my in trying to come up with all variants of words for dealing with Remove / Delete / IsNull, Not Null and… why didn’t I think of Clean… ?
But then one is forced to make lotsa good filters…
Usually there is no “Null”/None point, because Point3d is a structure. While Python can create None and assign it to any variable, strongly-typed .Net languages do not support None on plain structs. There is a special Point3d.Unset value, that is sometimes used for None. You can use is not None followed by and pt.IsValid. That will also filter out any infinite points.
So these spooky “null” value points are actually valid objects (technically speaking) while conceptually being so called “null-objects”? Well, I’ve heard that name for objects that actually do exist but is meant to represent “null” for invalid data values/structures as to avoid fatal crashes by accidentally referencing nil pointers?
Anyway, whatever method to be used, what I’m looking for is the super fastest possible, since I generate lots of (gh) points on irregular surfaces and need to filter them in several stages in order to gradually “close in” on my target surfaces, which means I have to filter thousands of points in lists.
Edit:
BTW,
Q1: are VB.NET scripts faster (assuming that vb script components gets compiled?)
Q2: does GhPython apply “boolean shortcircuit” in expressions like the following code which I call (“NullPtFilter”) for point list?
if pt_list:
P = []
for pt in pt_list:
#// collect only valid points :
if pt is not None and (pt.IsValid or (pt is not False) or (pt is not True))
P.append(pt)
Yes, because of how Rhino is setup, “null” / invalid might actually be something different than Python’s None. I mean, None is exactly always None, but there are some values that mean undefined/incorrect/unset data. This is similar to float ‘NaN’ (not a number, but it’s a float, still), which is documented in Python, too: https://stackoverflow.com/questions/944700/how-to-check-for-nan-in-python
It might be, but I doubt it will make a significant difference here.
The question here is whether Python applies shortcircuiting. The answer is, the Python "or" operator does. See the Python docs.
