I recently started building a code in vs for grasshopper comp, and i got it working mostly i just have this one issue with error CS1061, i cant seem to find the problem in the code and solve it. I am a newbie still, maybe its some dumb mistake i dont know This is the error message i get:
‘List’ does not contain a definition for ‘length’ and no accessible extension method ‘length’ accepting a first argument of type ‘List’ could be found (are you missing a using directive or an assembly reference?) Curve_Length
Here is the code:
Brep geom = new Brep();
double interval = 0.05;
DA.GetData(0, ref geom);
DA.GetData(1, ref interval);
BoundingBox bb = geom.GetBoundingBox(true);
double zmax = bb.GetCorners()[4].Z;
Curve[] krive = Brep.CreateContourCurves(geom, new Point3d(0, 0, 0), new Point3d(0, 0, bb.GetCorners()[4].Z), interval);
var podelat = 5;
DA.GetData(2, ref podelat);
//Point3d[] tacke = new Point3d[podelat];
//krive[0].DivideByCount(podelat, true, out tacke);
List<Plane> ravni = new List<Plane>();
String code = "";
String niz = "";
niz += "VAR robtarget targetlist{" + podelat.ToString() + "}:=[";
for (int i = 0; i < krive.Length; i++)
krive[i].DivideByCount(podelat, true, out tacke);
Vector3d vektorY = new Vector3d(0, 1, 0);
Vector3d vektorZ = new Vector3d(0, 0, 1);
Vector3d vektorX = new Vector3d(vektorZ);
vektorX.Rotate(Math.PI / 2, vektorY);
for (int j = 0; j < podelat; j++)
Plane ravan = new Plane(tacke[j], vektorX, vektorY);
ravni.Add(ravan);
for (int k = 0; k < **ravni. length**; k++)
Plane p0 = new Plane(new Point3d(0, 0, 1), new Vector3d(1, 0, 0), new Vector3d(0, 1, 0));
List<Plane> ravnica = new List<Plane>();
Quaternion q = new Quaternion();
q = Quaternion.Rotation(p0, ravni[k * podelat]);
code += "CONST robtarget Target_" + k.ToString() + ":=[[" + ravni[k].OriginX.ToString() + ", " + ravni[k].OriginY.ToString() + ", " + ravni[k].OriginZ.ToString() + "], [" + q.A.ToString() + ", " + q.B.ToString() + ", " + q.C.ToString() + ", " + q.D.ToString() + "],[0,0,0,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]];" + "\n";
niz += "Target_" + k.ToString();
if (k < podelat - 1)
niz += ", ";
DA.SetDataList(0, krive);
//DA.SetDataList(1,tacke);
DA.SetDataList(1, ravni);
DA.SetData(2, code);
