Created this setup for a special SubD/Nurbs workflow:
imported a level0 mesh from another app
1 converted the mesh with toSubD in Rhino
2 converted the SubD with toNurbs in Rhino
(all three objects on layers in the Rhino file)
3 referenced the NURBS Brep to Grasshopper
4 build a ridge line in Grasshopper based on referenced Rhino points
5 built the Grasshopper def to get control over the tangents of the ridge with sliders for each ridge segment.
Now to get e real relational SubD workflow i would need to perform the first two steps (toSubD, ToNurbs) in Grasshopper. This would give me the possibility to easily change the overall geometry by dragging the vertices of the original level0 mesh (same as the referenced ridge poits).
Unfortunately i am still on Rhino 6.
Any help or idea is highly appreciated, thanks in advance!
SDS_2_NURB.3dm (339.4 KB)
SDS_2_NURB.gh (39.1 KB)
