HELP: contour a geometry
I would like to contour this geometry, however I am unable to make the contour follow the curvature of the geometry (not being the X or Y axis).
I think this is a simple problem to solve, but I can’t find the solution.
estimulos.gh (26.1 KB)
Thank you!
Up.Load.Your.Code
Done!
What direction are you trying to contour in? Can you upload a sketch of what you are trying to achieve?
My idea is to achieve something like this: frames/sections follwing the curvature
Hi @Taynan_Saquet
You could use “intersect brep plane” for this.
estimulos_re.gh (31.4 KB)
That image is almost useless. Is this what you want?
No one could possibly help you without posting your code, please remember that.
I can’t find the solution either because there was no code posted in the marked “Solution”. And this problem was poorly defined.
Thank you so much!
It worked out! :slight_smile:
Thank you so much!
It really helped :slight_smile:
Hello Joseph, thank you for trying to help me. This is my 1st time using the forum and I do apologize for not using it correctly.
I already marked the comment with the code available as the solution if you are interested to see the solution.
That looks NOTHING like your description of the “simple problem”.
