I’m working on the solid railing of a stair and its comprised of curves from different construction planes. I’d like to smooth/blend/3d fillet (if that’s a thing?) these points in a controlled manner, but can’t find a command that allows me to do this consistently. I’ve been trying with both Rhino 7 modeling tools and grasshopper.
The blendcrv command is awesome, but it’s not consistent because it depends on how far along the line I click to start the blend.
How would you recommend doing this consistently as part of the design process? If you think there’s a better way in grasshopper I’m completely open to that too and can try posting on the grasshopper section.
Here are some examples and the file is included too:
Railing Lines (arrows show corners that I would like to smooth out)
Quick n Dirty method with blendcrv
Rhino 3DM File
stair.3dm (7.9 MB)
