I’ve developed a multi-targeted plugin for Rhino 8 that builds for both .NET Framework and .NET 8. As a result, I now have two sets of DLLs and RHP files—one for each runtime.
The challenge I’m facing is this: if a user switches between .NET Framework and .NET 8, how can I prompt Rhino to load the appropriate RHP file based on the runtime in use? Is there a way to configure Rhino to recognize and load the correct version automatically, or would I need to implement custom logic to detect the runtime and adjust accordingly?
Any guidance on achieving this runtime-specific loading behavior would be greatly appreciated!
Thats a great question. I decided to write a Rhino Launcher that starts rhino with the appropriate /netcore or /netfx switches so that I was in control for our users, and then loads our scheme/skin.
The latest Rhino Templates have all of this behaviour correctly set up so you can just get going with Debug on Win & Mac, net48 & net7.0, Visual Studio & VS Code.
I’d like to explain what I’m working on. I have a plugin built for both .NET Framework 4.8 and .NET 8.0. When I use Visual Studio or Rhino Plugin Templates, I get the same project structure for both versions.
My concern is how to package this plugin for distribution. Specifically, when I create an installer using WiX or Inno Setup, I need to ensure that Rhino can load the appropriate .rhp file based on the runtime. I’d like to know the best way to package this in the installer to handle this scenario.
Thanks @david.birch.uk for the recommendation. However, I’m wondering if there’s another way to achieve this without using a package manager.
I was thinking about creating an external Python script that will be executed whenever Rhino starts. This script would decide which plugin to load. But, is it possible to configure Rhino to run this script automatically every time it starts?
I’m not sure if this approach will work or not.
and this script should be shipped in installer.
Why do you want to avoid using the package manager Yak?
Plugins distributed via yak can have any number of framework specific versions included in the same package. net48, net7.0, net7.0-windows, net7.0-macos etc etc. which means as long as you multitarget using the <TargetFrameworks> attribute in your .csproj, (included by default in current Rhino templates) you’ll build your 2+ framework versions and yak/rhino will handle loading the correct rhp from the correct framework folder. You do not have to write any custom behaviour, it is automatic.
So if you run rhino in net7.0 on windows, it will load net7.0, or net7.0-windows if it can find that. If you run net48 on windows, it will load net48, if you run net7.0 on mac it will load net7.0 or net7.0-macos if available.
I see you mentioning net8.0, do you have a preference for net8.0 over net7.0? If so, why? Rhino runs using net7.0 or net48, I’d opt for net7.0 if you can.
Yes, @CallumSykes , we need support for .NET 8.0.
Thank you for your help! I tested a sample plugin with .NET 7 and .NET Framework 4.8 using the Yak package, and it worked as expected.
I think need to wait until Yak Package Supports .NET8.
