GumballAutoReset doesn't work
I suspect that the GumballAutoReset doesnt work in RH8 SR6.
Gumball autoreset is currently enabled but I’m looking at a block where the gumball is placed not on centre of the block.
GumballAutoReset.3dm (575.6 KB)
As seen in the video, GumballAutoReset was enabled and the position of the gumball wasn’t updated, only when GumballReset was run did the Gumball reset to the correct position.
Note: Volume inside block was made using a python script, (automatic extrusion to certain length from 2d curves to a linear volume). But this was never a problem in RH7
_SystemInfo
Rhino 8 SR6 2024-3-19 (Rhino 8, 8.6.24079.11001, Git hash:master @ 0d13b06881495403bd28e1cee93f8c8ea0baec7c)
License type: Commercial, build 2024-03-19
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2060 (NVidia) Memory: 6GB, Driver date: 1-18-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.23
- Windows Main Display attached to adapter port 0
- Secondary monitor attached to adapter port 1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-18-2024
Driver Version: 31.0.15.5123
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.6.24079.11001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.6.24079.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.6.24079.11001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.6.24079.11001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.6.24079.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.6.24079.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.6.24079.11001
C:\Program Files\Rhino 8\Plug-ins\BlockEdit.rhp “BlockEdit” 8.6.24079.11001
Hopefully you are able to recreate this bug so your able to fix it.
Thanks
Martijn
hi @Martijn I don’t see an auto reset of the gumball in Rhino 7 when reselecting a block. I do see a behavior change in Rhino 8 vs Rhino 7 though. If I drag the block and hit esc while dragging, in Rhino 7 the gumball stays put (out of center) while in Rhino 8 it resets the gumball.
I just logged this behavioral difference: RH-81205 Gumbal AutoReset acts differently in Rhino 8
Hmmm, your right. I thought it constantly updated the gumball.
I just downloaded the file and the gumball was correct again. So it does reset the gumball but only reloading the file?
Your comment about behavioral difference between Rhino 7 and 8 I see as well. Personally I never move the gumball so Rhino 7 behavior would be prefered to me
@Gijs,
I am seeing more and more blocks having there gumball not on centre anymore. Not sure what is causing it but there is some strange behaviour there.
Maybe I should rename the topic to Gumball origin misplaced or missing.
Example’s:
The same block twice, but one object the gumball is missing.
After running GumballReset it was fixed.
Other object also missing gumball
Ow wait its over at the world origin. Close to it but not directly on it, but it is close enough to it that its not a coincidence. I think this happend during some copy paste action? It was also fine before, but after re-entering the block it got misplace.
And of course when running GumballReset it is fixed.
Some notes:
  • Yes, this is all then same linked block but I have seen it with other blocks. Both linked and embedded link style.
  • I’m currently inside a block but I have also seen it inside the model space.
  • As far as I know, GumballAutoReset is always on
I have a temporary fix but its not ideal:
Blockedit macro:
_BlockEdit _SelAll _GumballReset _SelNone
I am also having this issue. As you can see below, AutoReset Gumball is turned on, and Align to CPlane is selected, but the gumball is not aligned. I can fix this by hitting Reset Gumball, but what is the point of AutoReset if it doesn’t do anything. Also, every time I close and reopen a file in R8, AutoReset Gumball is checked off. Is there a way to force this to stay on?
[GumballAutoReset doesn’t work]
This bug has not been fixed yet, why?
This bug almost broke me!!!
This is super annoying !
It’s the same exact thing on Rhino 8 for Mac.
Every time I have to manually Reset the GumBall…
@cultur @jadelbaba on which Rhino 8 SR are you?
This is how it currently works in Rhino 8.11:
I’m using Rhino 8 for Mac.
On version 8.9
hi @jadelbaba let me know if you want to try out 8.11 to see if that works better for you.
