Grouping adjacent numbers_EW.gh (7.8 KB)
Adjacent?
Wouldn’t ‘identical‘ be a better word?
Yes, I didn’t express myself very well
Can native components of Gh be used
What I want is consecutive identical
For example, the input list,[1,1,2,2,2,3,3,1], [1] will be grouped into {[1, 1], [2,2,2], [3], [1]}, and output with tree structure.
I changed the topic title for you.
@Eef_Weenink solution uses native components…
Uploading: 2.png…
Improve the functions
sir ,not what l want
‘Expression’ Perhaps screening can be achieved
Explanation:
- I have to divide a list in groups. So every time the next item is NOT the same, we want the number of that. This is done by shift list -1 (compare to item we have seen before).
- Idential then True. If not False (because you use text + numbers I uses Match Text)
- Using Dispatch we have a list of every first item of a group.
- Using List Index we have also the index number.
- We want to select these groups. With something like:
From First item to the one before next First item. So I use the Shift List again (Wrap = False, ) because we want only to end of list. - List Length to find last of list
- Series to make the numbers in every group.
- List item to finish it off.
Grouping adjacent numbers_EW.gh (7.3 KB)
@Eef_Weenink Awesome
Very good
