How to pass group object not rhino one but grasshopper group object to c# component?
What its type is?
It’s too late, by the time a geometry group is passed to a Script input parameter, it will already have been converted into a List<object>
where the data inside the list is the ‘ungooified’ stuff. So if you had a Grasshopper.Kernel.Types.GH_GeometryGroup
containing two GH_Brep
, a GH_Curve
and a GH_Point
member, you’d get a list containing (Rhino.Geometry.Brep, Rhino.Geometry.Brep, Rhino.Geometry.Curve, Rhino.Geometry.Point3d)
Case in point: groupparsing.gh (9.0 KB)
Thank you.
I have a bunch of different geometries in a group.
To get boundingbox of a group in scripting component, I need:
- to get inside of a group
- get each bounding box
- union all bounding boxes in a group ?
Or it is possible to do in one go?
No, the types inside a group do not necessarily have a base type in common that is bounding box aware. You’ll have to iterate. Easiest is to use the GH_Convert.ToGeometricGoo
method, but if you want to inspect each element yourself that will result in fewer instance constructors.
private void RunScript(object G, ref object E)
List<object> group = G as List<object>;
BoundingBox box = BoundingBox.Empty;
foreach (object element in group)
if (element != null)
IGH_GeometricGoo goo = GH_Convert.ToGeometricGoo(element);
box = BoundingBox.Union(box, goo.Boundingbox);
E = box;
