Grid Bubble in Different End Location
Hi Guys,
These are gridlines generated from GH to Revit but for some reason, the grid bubbles appeared in random end grid location, is there a way to place them in one end alignment?
Thanks
When placing the grids originally the Curve direction will determine the Grid Bubble location (start of curve)
You can use the Dir command in Rhino to see the Curve direction, or get endpoints and flip curves per a guide in Grasshopper.
Once placed you will need to use the Revit UI to modify bubble locations or flip your curves and change Element tracking to Replace (then switch back to Update after)
Thanks Japhy, l will going to try your advice, kind regards.
Hi @sketzjewel,
As in Revit UI the bubble should be placed at the end of the curve, but unfortunately there is a bug and is placed at the start of it.
This will be fixed in v1.9.
Thank you guys, anyway, I been using 1.9 version but not the official version yet, still having this bug.
We release each Tuesday, will be there next week on 1.9.
If you want to test it now you can use the daily build that is 1.10 an already contains this.
Thanks Kike, I will try this and hopefully the end bubble location is fix, cheers.
I want to grab existing grids with Query Grids and flip the bubbles. I don’t always want to build the grids from scratch. I believe pyRevit can do this, so it should be in the API somewhere. Do you know how I should accomplish that?
Hi Jmarsh,
This would involve a few methods.
The grid bubbles are view dependent
The bubbles are part of the Datum Plane Class
Then the ends need to be tested.
I had this below one available, I used in the past… hope it works as expected.
RiR_GridBubbleVisibility.gh (4.2 KB)
This is wonderful!
@Japhy Is it possible to add this function to RiR?
Yup! added it as a feature request.
Hi @ctu6,
‘Datum Bubbles’ has been added to 1.27. It works with Grids and Levels.
