12.3dm (421.1 KB)
I need the pattern in picture 1 in the outer walls of the building,
And the pattern in pic. 2 in the inclined surface with then open panels above the atrium space and along the space between the highest point & the lowest. (All using grasshopper)
Thanks in advance.
Hi @karimeladgham
Are you looking to hire someone? If so, kindly post under Jobs & Portfolios.
If you’re trying to create it yourself, kindly post the Grasshopper file showing where you’re stuck. It would be easier for us to help you.
Kaushik LS
Chennai, IN
