Hello there,
I hope all is well.
As you can see in the attached file, the curves are not lofting at the end of the algorithm.
Also, the Voronoi curves on the brep surface is not covering the middle part + some of the edges.
Thanks. loft issue.gh (16.1 KB)
loft.3dm (519.2 KB)
HS_Kim
March 28, 2019, 1:34pm
3
Looks like a typical data tree problem. See White group. For the second issue, move your bounding box slightly downward would help.
loft issue_re.gh (114.8 KB)
Hello again,
How about this time, why does the design exceeding the edge of the doOut of Circle Edge.3dm (543.2 KB)
me?Out of the circle edge.gh (14.6 KB)
That’s because your surface is a “Trimmed” surface. See the linked topic bellow if it’s helpful.
Hi guys! First of all I’m new with grasshopper. I’m trying to make my last degree project with grasshopper because he requires a parametric solution for the structure. It’s been really great, with alot of new steps every day to understand better the plugin.
Ok so. I can’t really explain why this is happening but I’ll try to be the clearest possible.
I’m creating a 6 vertices surface and I’m trying to subdividing with the isotrim/subsurface option. But everytime i trying to divide, I got this h…
