The error below appears after opening gh
I have installed the latest rhino 7 7.28 on my mac
Grasshopper display error
An exception was thrown inside the drawing pipeline:
Source: System.Drawing
Type: The method or operation is not implemented.
Hey @AdrianFranczak,
Thanks for reporting the issue! Unfortunately, it’s not enough to really go on to fix it. Do you have some steps we can do to reproduce the issue? Or are there any plugins you might have installed that are causing it?
Cheers,
Curtis.
Unfortunately, this still appears and I can’t work with Grasshopper.
Here is a basic file:
After I changed the size of the slider everything broke - but this is one way of many how to break this.
For me, this error means some system libs are missing, but obviously, I can’t debug this because I don’t have source code.
Rhino Version 7 (7.34.23267.11002, 2023-09-24)
Apple M1 Pro
MacOS 14.0 (23A344)
error.gh (1000 Bytes)
This is a clean install - I don’t have any plugins.
